I integraboomer New Member Aug 8, 2011 #1 Is there a way to tell a gsr/b16 tranny apart from an ls? I'm not sure if the tranny I got with my swap is a true b16. All it says is ysk 1
E_SolSi Member of the 20 nut club Moderator VIP Aug 8, 2011 #2 https://hondaswap.com/swap-articles/b-series-transmission-guide-29099/ the YSK-1 refers to the year of the case could be a cable B16 tranny from an OBD-0 B16A
josh_crewdson@y New Member Aug 8, 2011 #3 i thought somebody figured out how to tell by rotating the input shaft, and seeing how much the axle turns in a certain gear.. somebody find it, lol
I integraboomer New Member Aug 8, 2011 #4 SolSi said: https://hondaswap.com/swap-articles/b-series-transmission-guide-29099/ the YSK-1 refers to the year of the case could be a cable B16 tranny from an OBD-0 B16A Click to expand... It is a cable tranny.
B BIGROB90 New Member Aug 9, 2011 #5 yes it is a cable i have the same one in my crx and they come from the 89-90 da j spec models
redef91 Senior Member Aug 9, 2011 #6 only real way to tell is to drive it or take it apart and check out the gears.
GlassHeadlights West West Yall Aug 9, 2011 #7 My B16 with an LS trans was soooo slow. I'm sure you could tell if it had long or short gears.
