Tranny S40
Discussion in 'Civic and del Sol - EG and EK' started by Tein, Nov 28, 2007.
  1. Tein
    Tein So much with a little D
    Kissimmee, FL
    are all Civic S40 tranny are the same or they are different types?
  2. 99sidude
    Ohio
  3. Tein
    Kissimmee, FL
    that's the 5 speed tranny for the d16y8, but I hear that some are with a short shift....
    basically I just want to know if the 5 speed from a dx is the same at the one from a ex?
  4. haao13
    haao13 New Member
    PA
    id say no because the 92-95 dx and ex trannies are different. the dx has longer gears then the ex
  5. BrutalB83
    Rochester Hills, MI
    No, they're not the same. EX/Si trannies are geared more aggressively and have slightly shorter final drive ratios then the LX/DX transmissions.
    Why are you inquiring?
  6. Tein
    Kissimmee, FL
    Cause I have both at home and I they look like the same, actually both said S40 but one came out of a 97 DX and the other one from a 98 EX.... I am almost done with the swap... I just need to droped on the engine bay...
  7. Tein
    Kissimmee, FL
    i also made the Fucking mistake of adding new bearings and oil seal to the one that came from the DX,,,, So now I will need to spend more money on changing everything back to the EX one..
    that's what happened when you don't research.... Fuck!
  8. BrutalB83
    Rochester Hills, MI
    Yeah, I a lot of the D-series transmissions are simply labeled "S40". The gear ratios on the EX/Si ones are better though. If the EX tranny is still usable I'd go with that one, you'll accelerate faster.
  9. Tein
    Kissimmee, FL
    An by the way I will send the S40 DX.. If you know of some one let me know...
  10. safetyjoe
    safetyjoe New Member
    Hey a guy said that he has a S40 tranny out of an integra, is that possible?
