Tranny swap
Discussion in 'Civic and del Sol - EG and EK' started by civicnoob, Jul 5, 2007.
  1. civicnoob
    civicnoob New Member
    looking to swap the tranny to a 5 speed this weekend, i know that i need a tranny, clutch, slave and master cyclinders, linkages, pedal assembly, shifter assy, is there anything else that i need. and is it possible to swap everything in a day. any problem that people have had or any other input.
  2. EJ2*Whitey
    EJ2*Whitey Young Member
    Ruther Glen, Va
    Uhm..you probably already know but, flywheel, hydraulic lines, not sure about the axles i've heard you can use the auto ones and i've heard you should use the manual ones..so idk. but, good luck and if you have everything you need and somewhat have an idea of what your doing, it can be done in a day. =]
  3. civicnoob
    do i have to do any welding or anything like that or is it pretty much a straight swap
  4. EJ2*Whitey
    Ruther Glen, Va
