91_stylin_civic
Member
i have a b16a with a J1 trans been building the car for sometime now. well i was doing one last inspection on the car and found the passenger side axle seal looks like its leaking. i install new axle seals before i put the swap in. i moved the axle alil bit and i have some play up and down. i was thinking the axle may not be seated all the way which im hoping thats all it is and not a problem with the trans itself. the axle looks to be seated all the way in.the drivers side is good. the axles are for a 92 gsr(brand new) i could use some help. thanks
