Transimission install " The Bitch Pin"
Discussion in 'Civic and CRX - EF' started by CRX-YEM, Jan 5, 2009.
  1. CRX-YEM
    Wallingford, CT
    So anyone have any tips on how to remove "The Bith Pin" the pin that connects the shift linkage to the transmission ??
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    take a punch or big philips head and put it to the end of the pin and hit it out with a hammer,is the end of the pin sticking out at all??if so use a punch that wont go into the middle of the pin,becaus then you will mushroom the tip and have to drill it out
    o and instead of replacing the pin,use a bolt and nut
  3. 95b16coupe
    95b16coupe New Member
    ct
    just get a hammer and one of those pin punch tools.
    like here...
  4. D16SiHatch
    D16SiHatch New Member
    When i had to remove mine i also read that using a punch was the best way to go, however i didn't have one, and also i didn't feel comfortable smacking the shit out of the trans selector rod with a hammer. i invisioned the possibility of bending it enough to possibly cause shifting issues, or maybe even crack something. That being said i got creative and started searching my tool drawers. I used a small c-clamp and placed it around the bitch pin. then on one side use a socket that is deep enough to contain the entire wrist pin once its pushed out. on the other side use a square drill bit piece (or another bit that the business end fits within the pin). setup should look like this.
    then start turning it by hand till you cant twist anymore. grab some vice grips and use them to turn the handle on the vice. slowly the pin will start to push out and eventually fall out into the socket. all without bashing on things with a hammer :)
    Also i don't know if replacing the bitch pin with a nut and bolt is such a good idea. Aside from the fact that it could fall out and the havoc that might cause, a nut and bolt is not likely going to be a strong enough solid connecter between the linkage and gear selector. the point of the pin is to make an extremely rigid connection that has absolutely zero play. a nut and bolt is not likely going to accomplish this.
    1 person likes this.
  5. efhondakid
    Akron-Canton, Ohio
    Ive never had a problem with getting it out, you just have to be sure the punch you use is the same size as the pin.
  6. f22b1 coupe
    f22b1 coupe Junior Member
    Indiana
    Agree with all the above, I did a civic with no problem at all using a punch.
  7. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    thats usin your noggin! i totally agree with you on the possibility of bending the selector shaft..that would suck ass. i just installed one in my trans and out or in i hate dickin with it lol.. but the c clamp method is indeed a sure fire way not to damage the shaft for sure ^_^
  8. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I had problems with the clamp method because the socket kept slipping off. I've stuck with hammer and punch; if that doesn't work, add heat to the mix.
  9. Mike21
    Mike21 New Member
    Miami, FL
    Hammer & punch usually works. I've tried the clamp method with no success. Just lift the car high enough so you can get enough leverage.
    DO NOT put a nut & bolt in there once you get it out... Your shifter will feel sloppy. And do yourself a huge favor. Go to the Honda dealer and spend $4 on a new bitch pin. Try to avoid using the old one.
  10. INJEN78
    INJEN78 HS LEGEND
    OHIO
    a 10mm bolt woks just fine as a replacement pin,my boy has a type-r EF that he races,and he slams gears,hasnt had a problem yet
  11. K2e2vin
    Raleigh, NC
    There's a difference between slop and "working". :p
    I just went to Lowes and got a spring pin that would fit, and replaced it ASAP..
  12. D15Beater
    D15Beater HNFTuning
    Concord N.C.
  13. mesa50w
    mesa50w New Member
    I used the ac mounting bolt to get mine out, worked like a charm
  14. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    8mm punch and hammer ftw. That's the correct size it's how I got mine out.
  15. austin20110
    austin20110 New Member
    Northern Va
    if he hasnt gotten it off by now he is retarted lmao
