transmission help
Discussion in 'HYBRID -> ED-EF / DA' started by mygsr, Aug 13, 2005.
  1. mygsr
    mygsr Member
    LOS ANGELES
    hey people well i have a 90 integra with 5th gear and reverse messed up i have a frind who has a 96 integra gsr transmission can any one help me to find out if the gears would fit
  2. pugarex
    pugarex Senior Member
    kern co. california
    i would swap the tranny. thats just me though. my 2 cents.
  3. jdm2gen03
    jdm2gen03 Senior Member
    swaping the tranny wont work. but u can switch the gears. depending on the tranny case numbers. wat type of tranny do u have ie s1 or y1 or wat. and i can help more
  4. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    The tranny cases are different. One is hydraulic, the other is cable. Plus, the input shaft diameter is different, so you'd need a new clutch, also.
    As far as the internals being swappable, that can be done, but is hardly worth it when you can get a good condition 90-91 Teg tranny for $300 or less regularly.
