transmission problems
Discussion in 'Civic and del Sol - EG and EK' started by Blakwolf9666, May 29, 2011.
  1. Blakwolf9666
    Blakwolf9666 Member
    Miami
    well i have a 92 civic 5sp and the reverse gear grinds when the engine is cold, but as soon as its warmed up it shifts fine, first gear is also kind of hard to get into sometimes. I was gonna take the car to a shop to have them look at it and see if its the gears or just the clutch. and even if it is the gears i was gonna do the clutch anyway since its already out, but my question is other than what would cause the grinding is what kind of clutch/flywheel would be better? any info a.s.a.p. would be appreciated thanks
  2. E_SolSi
    when was the fluid last changed in it?
  3. Blakwolf9666
    Blakwolf9666 Member
    Miami
    That im not really sure about
  4. E_SolSi
    might be worth a shot before you go spending $$$$$ on rebuilds
  5. Blakwolf9666
    Blakwolf9666 Member
    Miami
    Yeah I was thinking that too, just seeing what others may think before I do anything
  6. BoosteDa
    BoosteDa New Member
    I would change out the transmission fluid. That's probably the cause of your problem. Rule out the smaller things before spending money on a rebuild that may not even be necessary.
  7. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    maybe the clutch isnt releasing all the way, make sure it has enough fluid, although i dont think temp would affect it that much
  8. E_SolSi
    :werd:
    replace the tranny fluid
    bleed the clutch line
    see how that works
  9. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    reverse doesn't have synchros, so if the gears inside the trans are spinning it's going to grind.
    put it in first, then put it in reverse.
    putting it into first gear stops the gears inside the trans from spinning, and it won't grind into reverse.
    fluid change isn't a bad idea either.
  10. Blakwolf9666
    Blakwolf9666 Member
    Miami
    ok when i do change the fluid does the car need to be up? or does it matter? or my main question would be if its not up would it change the amount of fluid in it? just the tranny side up or the whole front end? sorry for all the ???'s just havent had a civic and all my other cars were auto and was different lol
  11. josh_crewdson@y
    nova
    level ground. fill it till it pours from the check/fill hole.
  12. Khabbs
    Khabbs New Member
    Beacon NY
    be careful when you bleed your clutch , if you do a system flush you may end up have to by a new master. because of dirt being flushed that was holding seals together
