transmission upgrades???
hale97
hey guys, im in the middle of building a turbo ls/vtec and am putting a itr transmission in the car, is the trans going to be strong enough to handle the power out put? i know ill need a good clutch,just wondering about the gears/syncros?? any help would be great.thx
alright thanks, is there any brand/type you recomend? any one better than the next ? or just a good synthetic?
What is your power goal?
For transmission fluids avoid synthetic unless it's specifically intended for synchromesh transmissions. I personally prefer Amsoil or Pennzoil w/ Friction modifier. The newer MTF seems very watery compared to the older formula(probably to improve MPG?).
awesome, i am gonna be getting a centreforce dual friction clutch
because those suck and like to explode
soo....... i got another question for you guys then..... the engine i have is a b18a1,but the trans is from a type r, 1997 i think. so would i just order a clutch for the type r trans and a flywheel for a b18a? or are all the flywheels the same?
i like ACT for clutches... have had great luck with them... no complaints
flywheels are the same
