turbo and oil?
Discussion in 'Forced Induction' started by jasontyrone, May 24, 2007.
  1. jasontyrone
    jasontyrone New Member
    San Diego/Ramona, CA
    i just bought a b18 with turbo and they guy said that if i put 4 qts in the motor it will over fill the turbo. he told me that if i see hella oil smoke in the exsaust then i should drain some oil out of the motor is this a normal thing with turbos to run with only 2 or 3 qts?
  2. klyph
    klyph Dismember VIP
    North Pole, AK
    Did the guy who told you that try to sell you some crack?
    The only way your turbo will get too much oil is if it's run off of engine oil pressure with no restrictor. Also, I believe that only applies if you have a non-ball bearing turbo. Either way, you should never run your engine a quart low on oil, and only 2 quarts will cause bad things to happen. Your house will burn down, your dog will die, and your mother will be raped by a gang of unshaven illegal immigrants.
  3. nootrac22
    exeter pa
    :lolhammer:
  4. pissedoffsol
    that, or the return line is in the wrong spot on the pan and too much oil fills it up or some shit. sounds like you bought a timebomb.
  5. jasontyrone
    were
    where on the pan should the oil line be its now at the far driver side (LHD) of the pan.
