turbo b16 not building boost
Discussion in 'Forced Induction' started by 93y7, Jun 13, 2009.
  1. 93y7
    93y7 New Member
    my wastegate has been opening and running four psi. it is dumping right out of the wastegate. i have the wastegate pointed up. after i put my hood on it ran 4psi for about 10 minutes. after that my turbo spiked 15 psi and then it stopped building boost. the breather i have on the valve cover is smoking now when the car runs. exhaust smokes a little now. can anyone help me? could it be that the wastegate was blowing into the hood and maybe backing up?
  2. gettocrx
    gettocrx Member
    Honolulu, HI
    If there's smoke coming out of the valve cover, you coud have blow by. other then that see if the wastegate is stuck open and make sure the couplings are on good..
  3. 93y7
    93y7 New Member
    all couplings are on good. no oil in intercooler piping. the bov goes off but have no boost. maybe leaking out somewhere. where would it be going tho
  4. 93y7
    93y7 New Member
    rings are toast. have 60 and 90 compression in 3 cylinders. add oil and compression is high
  5. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    did u figure out why the boost spiked so bad?
  6. 97hatch
    97hatch ?
    Anderson IN
    boost spike and lack of a tune up thath high probaly cracked a ringland i had a silicone hose burst on a single cam i built and it spiked to like 25 really quick and it was under full load when it happpend blew every rod out the bottom of the pan and one got stuck in the radiator was not a good day. I now program a boost cut in every car i tune to prevent a over boost situtation
  7. 93y7
    93y7 New Member
    i think it was my fault. i couldnt get a dumptube fabbed so i pointed the wastegate straight up and i think it was so close to the hood it restricted the flow of the wastegate.
  8. 97hatch
    97hatch ?
    Anderson IN
    you pointed it up at the hood were you trying to burn the car down
  9. 93y7
    93y7 New Member
    stupid idea.. i know... was anxious to drive it. my stupidity cost me alot of money :confused: does anyone know if i have to notch my block to run eagle h beam rods?
  10. DESPAIN
    flower mound TX
  11. Matts96HB
    Matts96HB . Moderator VIP
    Why not just point it down? Or to the side? Anything is better than at the hood. That's just asking to bake the paint and bubble it.
  12. DESPAIN
    flower mound TX
    i just got a dump tube for my wastegate. i could tell a differance in temp almost instantly. not only is heat an issue but also your sucking in hot exhaust gas instead of just air.
