Turbo Build Up
Discussion in 'Engine Building' started by MrGsrDude, Feb 27, 2003.
  1. MrGsrDude
    MrGsrDude Junior Member
    If I were to get a B18C GE bare block I know I would need pistons/rods/crank
    but what about other internals what do you guys recomend I change and how much would it cost including labour? I wantt to make the block bullet proof my goal is to run 300whp on the streets daily driven and 400whp for track
  2. civicSiR1
    civicSiR1 Senior Member
    well you can do a lot of mods to your internals, problem is good luck on the 300 to 400 hp.....i have Toda/Spoon Fully built all motor and only have 262.....only that i'm running 11s.....why just don't you get the spoon engine assembly, comes with everything....oh and if money is a problem, try JE rods and crank, or JUN stroker kit....
