Turbo in a K20A2 swap?
Discussion in 'Fit and Jazz' started by filipin0dude, Apr 11, 2010.
  1. filipin0dude
    filipin0dude New Member
    Im looking into dropping a K20A2 motor into a honda fit.... I know ill need to get parts from the civic si: shorter axles, intake manifold etc. but I would like to also put a turbo kit on it, is this realistic, is there enough room?
    also I heard that replacing the k-pro causes loss of dash functions? and there are new ecus out, so when replacing the k-pro ecu do you have to also replace the other stock ecu?
