turbo question
Discussion in 'General Tech and Maintenance' started by mozzandherb, Mar 23, 2006.
  1. mozzandherb
    mozzandherb Senior Member
    I found a turbo that is compatible with the h22 swap into an Accord. I had a question though. I have a 4th Accord and this turbo is made for the h22 into a 5th gen Accord. Is there much difference between the 2 different Accords? What I mean is would this turbo which is meant for the 5th gen be just as compatible with the 4th gen Accord? Thanks
  2. josuedc2
    josuedc2 Senior Member
    Buffalo,N.Y
    I think the tubbing changes
  3. mozzandherb
    Do you know how much the tubing would cost approx?
  4. mozzandherb
    Anyone ever heard of a South Florida turbo manifold....if so are they good?
  5. preludebuddy
    preludebuddy Senior Member
    putting the rad in colorado
    I've heard of them...never looked into them though. the tubing can cost anywhere from 50 (homemade) to about 300.
  6. reikoshea
    Dallas, TX
    the piping wont work, and most of those ebay setups are trash. if you make friends with guys at a muffler shop, im sure you can get your intercooler piping cheap (down pipe too).
    we have a lot of threads on here about this stuff...the best way to go is to build your own kit...in the end it will work better and it will give you what you want.
    stuff youll need:
    Injectors
    P72/P28 ECU
    Ostrich (or a chip burner, but i prefer ostrich now that ive used both)
    Crome
    Manifold
    Piping
    Intercooler
    Turbo
    Down Pipe
    Wastegate
    Blow Off Valve
    Intake Filter (dont forget this one...i saw a Eclpse/Talon [guy had wrecked each and kinda....made one car] lose its GT35R turbo this weekend, because a rock got sucked into his intake)
  7. mozzandherb
    Should I upgrade my fuel pump and filter? Also the one I'm looking at isen't one of those ssaotochrome kits.
  8. reikoshea
    Dallas, TX
    pump definitely...filter you can just change and be okay. i dunno how i forgot fuel pump on that list....probably cause my car already has a new one.
