Turbonetics Deltagate Mark II wastegate
A never used turbonetics deltagate wastegate. This is a high flow external wastegate that can help you control boost. It can also be added to a factory manifold (with fabrication) to reduce the backpressure in your restrictive stock manifold/turbine and therefore make more horsepower!
It was purchased as part of a kit, however, was never used because a bigger unit was used (a racegate). Comes with a 5 pound pre installed spring (can be taken higher with a MBC, or springs can be changed or shimmed, - other springs available through Turbonetics).
Paypal or certified check/bank drafts only. Buyer to pay $10 shipping to continental US/Canada for ground. More if you want air or any expedited service.
$225
contact me at sean.silvera@apricotos.com
