Originally posted by JDM_EF@Feb 8 2005, 12:07 AM
I have an EF SI and my turn signals dont work and every time that i put a fuse in the turn signal slot and turn the ignition over to the acc position it blows out. The emergency lights work and when the lights are on the corners turn on but dont blink.
[post=457809]Quoted post[/post]
Originally posted by civicious@Feb 8 2005, 08:59 PM
If the hazards work, the problem isn't the blinker module. If you're blowing fuses, my money would be on something grounding out. Check to make sure that the wires for the blinkers aren't cut or something like that...
[post=458417]Quoted post[/post]
