Turning down boost
ImportImpaired
Loolong at a civic with a D16z6 that's tuned at 230hp on stock internals. I'd read around that 200 is as far as it should be pushed on stock internals, so my question is, would I be okay to just turn down the boost to retard the hp? Sorry if it's a dumb question, just never played with anything turbo.
no, you'd need to re-tune it ta that psi.
if it's been TUNED to 230, its probably pretty safe. try to get a dyno plot with a/f
after initial tip-in, steady/flat, and under 12:1. mid 11's to 12 is ideal
something like this.
a/f is the thinner line (scale at right ) on the bottom
230 on a stock D series internals is safe as long as the tune is good. I would get it retuned just to be safe. And make sure it has ARP head studs.
Thanks for your input, but I am sure he has probably decided on whether or not to buy the car by now. This thread is over four months old.
4 months is what I see. But you're right...he probably made his decision.
