TYPE-R VS. GSR for a CR-X EF motor swap...
Discussion in 'Civic and CRX - EF' started by CR-X - SI - GSR, Dec 8, 2008.
  1. CR-X - SI - GSR
    CR-X - SI - GSR New Member
    what is everyones opinion on this subject?
  2. 95b16coupe
    95b16coupe New Member
    ct
    read more, stop spamming the forum.
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    depends on cash flow,
  4. CR-X - SI - GSR
  5. 95b16coupe
    ct
    if you have a cr-x. just get a b18a swap and start there. it will cost about $1000 to get installed. get a suspension and brakes. learn how to drive. be done with it.
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    word..ls in a crx is pretty quick
  7. eg6sir
    not that quick.. my b16 eg ripped on one.. ..
    but yea.. gonna have to agree on the b18a swap.. easiest and cheapest other than another d-series
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    just gotta now how to drive,they are decent quick over dseries
  9. eg6sir
    with the right tranny that is..
  10. CR-X - SI - GSR
    yea thats what i've basically decided on. just not finding any in that 1000 price estiment
  11. 95b16coupe
    ct
    try craigslist etc. just shop around and be patient. if you can get a good deal on an obd0 b16, that would be good too.
    try
    Specializing in JDM-USDM Engines & Parts...hmotorsonline.com
  12. CR-X - SI - GSR
    ok thanx. got one more question for u guys. my cr-x is sitting right now do to a few suspension issues. i figured id do the swap and suspension at the same time. i got it looked at by freedom tire in iowa. on the list of problems they listed cradle - bent? what is a cradle. cooudlnt find any info
  13. 95b16coupe
    ct
    i have never heard of that. you would need them to show you.
  14. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
  15. CR-X - SI - GSR
    thanx that makes more sense then just bent cradle
  16. Briansol
    you won't get a GSR in there for 2700 bucks, let alone a type R.
    both are out of your budget, considering the change over is going to run you more than your budget with shipping... and that's before you score a cable b16 or ls tranny (or retrofit your car to use hydrolics), mouts from hasport, etc, and all the misc fluids, tools you don't have, etc etc to get it done.
  17. CR-X - SI - GSR
    i figured that. tools, fluids stuff like that no problem. i wouldnt put it in my shop would do that for nothing. most parts would be in a full swap which is what im saving for. thanx for the input
