b16a91crxsi
I'm putting a Type-R manifold on my B16A swap I just got, can you give me more info on exactly what I'm going to need for this job? like what fuel injectors, (B/c if I go w/ the newer fuel rail like stated below aren't the fuel injectors OBD1-2 sensitive where I'll be running OBD0) also what exactly is the GS-R EACV? and is an after market fuel rail such as AEM good enough w/ what I have or do I need the whole set up from one of these others? I have the whole factory intake setup but am I really needing to change anything?Thanks.
I got this information below from http://b16a.honda-perf.org/extras.html
The intake manifold - if it isn't complete you'll need a '92-5 Civic EX/Si or '94-7 Del Sol VTEC or '96 Integra GS-R EACV, as well as a fuel rail from either the twin cam VTEC Del Sol or the '94 Integra GS-R. Yes the B16A tb bolts to the R manifold although you might want to match port it
