Uh Oh!!
Discussion in 'General Tech and Maintenance' started by Citizen_Insane, Mar 21, 2004.
  1. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    When I pulled the old sparkplug wires out of my b16'a head, I noticed that the the #2 cylender's sparkplug hole had some kind of liquid on it and the sparkplug wire for that sparkplug had this white stuff (looked like the calcium deposites you get in sinks and bathtubs) on it. Is this bad, or did some rain water just get into the hole??
    Thanks
    -Kai
  2. Capt. Orygun
    Capt. Orygun Win the Day
    Oregon
    I'm not sure about the liquid our side of the fact that if it's oil, or if you have standing water on your cylinder (use a flashlight and look) then ur in big trouble. About the "white stuff" assuming u didn't blow ur load when u realized the awesome power of the B16 it's prolly just oxidation on the plug, meaning that it's about time for a new set.
    Thank you drive through
  3. Citizen_Insane
    Minneapolis
    I'm pretty sure its water...I sopped some of it up with a paper towel and it smelled REALLY REALLYR REALLY (repeat 10000x) bad...I almost puked. I think something rotted in there. Is this really bad? What does it mean? please tell me!!!!!!!!! THanks.
  4. GSRTURBO
    GSRTURBO Member
    if u have water in your cylinder, you probably have a blown headgasket
  5. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    is there water in the engine bay as well?
  6. uptowng2ic
    uptowng2ic Member
    NY
    Is there anything else that is wrong with your ride other than water being in the #2 cylinder......i.e. like weird looking smoke coming from your exhaust?
  7. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    r ur spark plug wires sealing around the ring thing on the valve cover? I seen a kid who put single cam wires on a dual cam and the seal ring thing on the plug wires is smaller, so when he drove in a lot of rain or washed his engine there was water down in these. also some times when u buy a jdm engine they power wash them and water gets in there because of such high pressure of the water.
  8. Citizen_Insane
    Minneapolis
    ^^^ that last thing you said is probably it...because I just recieved the engine...its a JDM b16a SiR 1. So I don't know if it smokes or anything, it doesnt run yet!
  9. cycloneb18c3
    New Jersey
    my old bosses ITR motor came with water down the spark plug holes, so thats how I knew. its a bitch getting it out isnt it?!?
  10. Citizen_Insane
    Minneapolis
