Unchipped P28 W/b16a3?
Discussion in 'HYBRID -> EG-EK / DC' started by dansace, Jan 10, 2003.
  1. dansace
    dansace Member
    ATX
    I was wondering if I can use an unchipped p28 ecu with my b16A3? If so waht are the pros and cons? Thanks.
  2. mrblk
    mrblk Member
    bay area, CA
    what do you mean unchipped? i would assume you mean a chip to take off the rev limiter and speed limiter
    pros cons,
    asuming you build up motor internals it can let you rev higher than the factory ecu, if you havent prepared your motor for the higher revs, it also gives you a chance to destroy your motor very easily.
    speed limiter, no real cons asuming you know not to go 130 on city streets, just disables fuel cut.
    the air/fuel map will also be different if it is supposed to be for a different motor, i will leave it to someone else to answer that end of it, as im not to sure of the differences there.
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    actually, an unchipped P28 is just a 92-95 civic ex ecu, which is sohc vtec... i actually had to run with this horrible ecu on my B16 for a day to pass smog (was actually the 96-98 ex ecu, pretty much the same but OBDII, long story) the cons are, the fuel mapping is all wrong for it, vtec kicks in too early, and the revlimit hits at like 7,000?? something like that, but it is not very fun. it will run the motor, but i dont reccomend it. i now have a skunk2 chipped P28, which works nice :) little rich, but i've fixed that with a vafc.
  4. dansace
    dansace Member
    ATX
    Sorry if I sound uneducated (because I am when it comes to swaps) but I would like to learn. I have the chance to get a p28 but as I understand it was not made for my engine. The donor car that my engine came from was in a bad accident and the ecu was crushed. I was wondering if the p28 would even work or would I need to get it chipped to work with my engine. This is what I was told and I just wanted some other feedback. Thanks for your help!
  5. dansace
    dansace Member
    ATX
    B16-thanks for the input....I would be better off just trying to find a stock p30 or a chipped p28 then right?
  6. mrblk
    mrblk Member
    bay area, CA
    being un-educated and being ignorant are 2 different things, if you were being ignorant, i dont think you would have gotten any help.
    its good to se people actually interested in learning things, instead of alot of people asking silly stuff, like if they can put a s2k motor in a civic (yes it is *possible*, but not really )
    so no need to appologise for asking questions, thats what the board is for.
    heh, not that i am claiming to be any kind of 'expert', dont take it that way, if you want an expert look to calista or pissedoffsol, amongst others
  7. dansace
    dansace Member
    ATX
    Yeah I want to learn, especially because I got a good deal on my b16 and don't want to screw it up because I'm "uneducated". Every reply is appreciated. I figure this the best place to learn, I beleive I can learn alot more from you guys than I could learn in a book or manual. Thanks again.
  8. mrblk
    mrblk Member
    bay area, CA
    heh, good luck with your motor, also if you are interested in a really cool chip check out hondata
    check out the vids of the full throttle shiffting
    http://www.hondata.com/media.html
    a bit pricey though
  9. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    yeah i suggested a p28 (because they are easier to find) and just run it, for a little bit till either he finds a p30 or till he can find somebody to chip that ecu for the a3
