unknown intake mani
Discussion in 'General Tech and Maintenance' started by pboyrocker, Oct 30, 2007.
  1. pboyrocker
    pboyrocker New Member
    can some one help id this intake mani. Thanks
  2. norcalgsr
    NorCal
    Should be a 92-93 Integra GSR manifold from a B17 based on the P61 stamp on it.
  3. pboyrocker
  4. pboyrocker
    you realy a honda master tech?
  5. norcalgsr
    NorCal
  6. pboyrocker
    i'm working on my ase's. will get some nocked out next time it comes around.
  7. norcalgsr
    NorCal
    Good luck they're a lot easier than they make it seem..
    If you buy the study guides it basically covers everything that is in the ASE tests.
  8. pboyrocker
    will you be on for some time i also have a head that i cant figure out. will take a pic real qick.
  9. norcalgsr
    NorCal
    Maybe.. if not I'll be around soon. There's a lot of other very knowledgeable people around too so post it up.
  10. pboyrocker
    need help with this one too.gotten alot of diff answers about this head. Will the IM work with this head?
  11. norcalgsr
    NorCal
    Yeah it should work.. that PR3 head is from either an SIR-2 B16a or a 92-93 Integra GSR. Either way the intake manifold should fit since they are both B series engines.
  12. pboyrocker
  13. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    yes he is right but please get that thing hot tanked before you put it on anything.
  14. pboyrocker
    i plan on getting it cleaned up with the block and maybe ported.i'm building an ls vtech which i'm taking my time with. No cutting corners just right building. it almost looks like its been ported.
  15. vtecsir1
    Orlando, FL
    well there is a link to my budget lsvtec build i did in my sig if you need any extra reading up on it.
