just odered it!!! took a while but finally ordered it!!
94'
JDM B18C
39,xxx Miles
LSD
ill get pics when the engine come!! should take 8-9 days for it to come!!
-Mike
hello everyone,
i am finally going to order my swap from HMO tommorrow!!!! B18C1 into a EG coupe(EJ1)
there complete swap comes with this...
- Motor
- Hydraulic Tranny (S80, Y80)
- ECU (P72)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300) im getting this.
im going to check what condition the timing belt is in. hopefully the clutch will be in good condition averaging about 35,000 miles on there motors.
THIS IS GOING TO BE MY FIRST TIME SWAPING AN ENGINE!!! and i want to make sure i am prepared...and i know things wont go perfect, but im hoping for the best.
now when swaping the motor, this is what i have come up with to get the SOHC out. drain the oil, coolant, tanny fluid, etc. then unhook and take out the wireing harness(maybe even lable the wires). unhook the axles, shift linkage, and clutch.
there will probobly be little things that i will find in order to take it out, but for the most part am i on the right track?? and what other infomation can you guys give me??
also, im giong to pull the motor out from the bottom, and put the new one in from the bottom. and i will have 2-3 friends helping me also, 1-2 which have done the swap.
any other information will be GREAT!!! thanks for reading all of this, im really excited about this project and right now i think im just going to ramble on....so im going to stop typeing.
thanks again,
-Mike
94'
JDM B18C
39,xxx Miles
LSD
-Mike
hello everyone,
- Motor
- ECU (P72)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
thanks again,
-Mike
