Usdm Type R Headers Any Good For The B18c1?
Discussion in 'HYBRID -> EG-EK / DC' started by ASpec818, Feb 16, 2003.
  1. ASpec818
    ASpec818 Junior Member
    i was getting the usdm type r headers put into my hatch along with a gsr motor. I know that the jdm has good performance gains but is there a difference between the usdm one? Will i be better off using the usdm type r headers of should i just use the stock gsr header? I will also be using the usdm itr cat.
  2. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    The ITR header is for a b16 head, you will have to make flange mods for it to fit a b18c1 head, IF it will even fit.
  3. ekPhred
    ekPhred Senior Member
    is there any kind of difference between the usdm itr header as opposed to the jdm one? i thought they both had a 2.5 collector? i could be wrong. enlighten me.
    peace!
  4. Domeskilla
    Fort Wayne, IN
    USDM 2.0 collector
    JDM 2.5 collector
  5. ASpec818
    it bolts right up. the usdm type r headers fit the usdm gsr. my car is almost ready.
  6. civicSiR1
    civicSiR1 Senior Member
    ITR has no IAB. I think it won't trigger a light. it bolts on like dick and pussy.
  7. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    no one is talking about the intake manifold . so iab codes wont be a problem
  8. B16
    B16 Super Moderator VIP
    yay area, CA
    wrong, it will bolt up, its the intake side you have to worry about on b18c1's, they exhaust manifolds are swappable.
  9. SixtySecondAssassin
    Austin, TX
    are usdm itr exhaust manifolds the same design as the jdm ones, besides the collector?
  10. ekPhred
    thanx for the knowledge domes!
  11. E_SolSi
    no they are a 2 peice 4-2-1 just like all the other honda/acura i-4's... probly better than most but still not as good as the JDM ITR
  12. ASpec818
    yep bolts up perfectly. all b-series fit all b-series (as i know now). i also got a usdm itr cat connected to the headers.
  13. pissedoffsol
    yup.
  14. Domeskilla
    Fort Wayne, IN
    I said you might have a problem b/c when you go look at headers, you see a lot of them saying "does not fit GSR".. My bad tho.
  15. pissedoffsol
    only the intake side bolt patterns are different on b-series heads.
    the only other probelm that may arise is that it won't clear the oil pan. a b16 is physically a shorter deck. if it cuts it close on a b16, it prob wont fit a gsr or ls
