V-tec or Turbo !!! V-tec v.s. Turbo
Discussion in 'Forced Induction' started by jap-spec, Oct 22, 2002.
  1. jap-spec
    jap-spec Member
    I'm giong crazy trying to decide if i can do both. I'm coming to the conclusion that you can either do one or the other. I fyou want to go v-tec you need higher compersion pistons. If you want to go turbo you need low compersion pistons. I don't know how to make it work so you get the best out of both. I don't think its possible. help!!!!!!!!!!!!!!!!!!!!!! I'm think i'm just going to go for ls/turbo
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    It is possible, just more expensive. Have you ridden in both kinds of car? If not then go ride in a boosted car and then ride in a well built NA car and decide which one you like more. The LS turbo is a great option. So is A B18C or a B16 built for high comp and high revs.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    If you want to go NA VTEC, then yes you want higher compression pistons.
    If you want to go turbo, you want lower compression pistons.
    If you want to go turbo AND VTEC, you want lower compression pistons.
    It's doable... just harder to tune. The rewards are well worth it though!
  4. jap-spec
    jap-spec Member
    Thats for making a piont that i already know. Yes my friends have some of the fastes n/a in from are area and i had a turbo eclispe. i felt both. I love turbo and never want to go back to normal but i was thinking vtec and turbo would be sick. I don't know what compersion i should have. If i go turbo with low compresion with a v-tec heasd,will the v-tec still kick in with low compresion?
  5. B16
    B16 Super Moderator VIP
    yay area, CA
    of course, vtec is the mechanism of changing cam lobes and timing... thats it... its the valve overlap that will kill you, use at least stock cams on there, if you want to be really serious about it, get some skunk2 turbo cams, i think crower makes turbo cams for the vtec too... it will be easier to tune with lower compression..
  6. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Yeah Skunk2 make turbo cams. That is what I am putting in my D16Z6. VTEC will work with lower comp pistons. 2 very different things there.
  7. pissedoffsol
    you are a rude bastard.
    you were rude to me in the other thread, and now you are rude to him.
    im done helping your ass.
  8. jap-spec
    jap-spec Member
    Thank for your reply. Its a very good opinion and honda engine are design to last. I wonder why they haven't came out with a turbo car.
  9. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
  10. pissedoffsol
  11. calvin
    calvin Senior Member
    NETHERLANDS
    mr knowledge where have u seen the d16z6 turbo cams from sunk2
  12. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    By the way, it's not v-tec. It's vtec. There's no reason to hypenate it.
    Variable Valve Timing and Lift Electronic Control.
  13. jap-spec
    jap-spec Member
    wow i'm sorry if you feeling got hurt pissed, you want to talk about it.
  14. SolReaver
    SolReaver Senior Member
    man jap-spec, you are a bitch
    there are a lot of educated people on this board that can help you with tech questions, and you are being a dick to them
    if i was a mod i would ban your ass
  15. calvin
    NETHERLANDS
    SolReaver i''m thinking just the same.
  16. pissedoffsol
    i run hondaswap.
    if you have a problem with me, you have a problem with the site, and the site has a problem with you, and then your chances of learnign anything here are slim to none.
    don't fuck with god
  17. E_SolSi
    hey jap-spec.....
  18. SolReaver
    :werd:
    :worthy: pissedoffsol
  19. pissedoffsol
  20. knowledge
    Beale AFB, CA
    www.skunk2.com
