v-tec solenoid ?
Discussion in 'General Tech and Maintenance' started by chap_e77, Apr 27, 2005.
  1. chap_e77
    chap_e77 Member
    OK I bought a vtec solenoid from this guy. but it only has the one wire plug on the solenoid itself, but there is no oil pressure plug on it, nor is there a slot for it. What
    solenoid do I have and will it work on a obd1 ls/vtec.
  2. tellos
    tellos New Member
    I have a H22a/200hp 96.. mine have the same solenoid ass you, whitout the v-tec pressure swi and ob1 ecu..I dont know if it works.. I`m having a hard time to get the wiring togheter afther my swap from f23a1 the engine runs but i dont have the v-tec....
  3. suspendedHatch
    suspendedHatch audio/security
    The JDM solenoids don't have an oil pressure switch. The oil pressure switch is unncecessary. It's there on the USDM models to prevent you from going into VTEC if your oil pressure is low. You can simply ground the ECU input, or do what most people do and join it to the VTEC wire.
  4. tellos
    tellos New Member
    It will work on p13 ecu..
