VA Inspection Questions
Discussion in 'Mid-Atlantic' started by Just2Much19, Mar 25, 2007.
  1. Just2Much19
    Just2Much19 New Member
    Sacramento, CA
    I am, moving to Va probably shortly and I have a 92 with a b16. How hard is it to pass inspection and emissions in ALexandria? Any help would be appreciated.
  2. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    no clue but i read your post, just to reassure you.
    comparing to california i doubt it is much different, since cali+car= nazi regulations
  3. BodyDroppedNikes
    caught in a mosh...
    they dont do smog checks in Virginia. just make sure your tires are good, horn works, all lights and turn signals work, full exhaust with no holes or missing parts, windows are good, brakes are good, your suspension is good and at legal height. thats basically it.
  4. Just2Much19
    Sacramento, CA
    Thank you!!
  5. thewraith
    thewraith New Member
    Errr..wrong. Northern VA they do strict emissions checks. I live in Alexandria- you have a smog check if your car is obd1 (sniffer) and if obd2- they hook you up to a scanner.
