Vaccum lines
92civicb18b1
The Trisexual
Ok I accidently ripped the vaccum lines from the throttle body off and the other vaccum lines that were t'ed off from it. I know that the main one goes to the thing on the firewall then to the throttle body, but where does the other one go?
Are you talking about the coolant lines at the bottom of the TB or the one Vacuum on top.
If the coolant lines are what your talking about one goes to the sensor on the back of the manifold and then goes through the TB, and finally to the head. Underneath the dist.
I figured it out, never thought that could fuck up my idle so bad, it was both I had just kind pulled them off without even lookin and did'nt know where they went. All I can say is 1 little vaccum hose will fuck up your idle BAD. I couldn't figure out why it was tryin to idle at 300 rpm (yea 300).
