vacuum hoses?
92civsicH
I put the h22 motor in my 92 civic cx and i finally finished wiring the damn thing. However, now i am just curious about the numerous vacuum hoses that are cut on the motor. I assume some of these are for the power steering, power brakes, etc...none of which i have now. Does any one know if these hoses are functional and need to be replaced, and if so..which ones?
Thanks for your help
you need positive vacuum (from the manifold) for the basics, MAP sensor (if not throttle body mounted), fuel pressure regulator, brake booster, and PCV valve. That will get the engine running, you can cap all the rest off.
