4drcivicb18a
Member
Ok so I know you have to run the vacuums for the bov, wastegate off a vacuum from the intake manifold or a vacuum line coming off of it.but not sure what ones to use.
WASTEGATE- I heard you have to make this vacuum as short as possible but if you dont have a MBC how would you do this or is ok to run a line straight to the IM?????
BOV- can I just run this line to any vacuum ? which one is best? do I even need a line for the bov?
BOOSTGAUGE- can I run a line right to the IM? Or is better to run it to the vacuum that the wastegate is and tap into that one? Thanks
