Valve Cover bolt down sequence
Discussion in 'General Tech and Maintenance' started by jfields0622, Dec 19, 2008.
  1. jfields0622
    jfields0622 New Member
    Does anyone know the valve cover bolt down sequence, for the DOHC ZC (black top year 1991)
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    Hard to type out. there are 4 near the spark plugs (we'll call these inner set), 4 on the outer edges (outer set). "Top" meaning intake side, "Bottom" meaning exhaust side. These directions are assuming you are standing in front of the car looking at the motor.
    1: Inner set, top right
    2: Inner set, bottom right
    3: Inner set, top left
    4: Inner set, bottom left
    5: outer set, top right
    6: outer set, bottom right
    7: outer set, top left
    8: outer set, bottom left.
    Get all the nuts finger tight, then torque to 86 inch pounds. DO NOT overtighten, it will only cause leaks.
  3. HonCiv99
    HonCiv99 EK Swappa
    UT
    Good write up, but may I also suggest buying a Haynes manual. Very very helpful when it comes to bolt sequences.
  4. efhondakid
    Akron-Canton, Ohio
    Ive never torqued VC bolts just snugged them up.
  5. MthaFuknGreen
    Lodi, CA
    i think his point was; dont over tighten.
  6. D16SiHatch
    D16SiHatch New Member
    Yea they're not like head bolts. a tightening "sequence" isn't really necessary. just snug em up and be done with it.
  7. phyregod
    phyregod !!YTINASNI
    Central Texas
    It is needed. You start from the outside and work your way in, it'll buckle the gasket in the middle and leak. This is the safest way to seal the gasket without pinching or buckling. They have bolt sequences for a reason.
  8. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Its just a common sense thing. Bolting it down right will help for leaks but its not like you'll screw anything up. Do as phy said if your worried.
  9. 94H_Ex
    94H_Ex Under employed
    Florida
    Well for your 1.5/1.6 engines. I dont believe it really matters being theres only like 5 or 4 bolts. but for his ZC DOHC it will matter. being theres more bolts and such.
  10. JKOBD.com
    JKOBD.com Wiring Guru
    Engineer at the Source
    Recommend Helminc.com
    Much better than Haynes.
  11. MthaFuknGreen
    Lodi, CA
    yeahh.. helms rocks.
    i just wish i had a credit card so i could order one, cuz the one i have is on my computer.
    ill never go back to chiltons or haynes again.
