Valve guide removal
Discussion in 'General Tech and Maintenance' started by Sabz5150, Mar 3, 2004.
  1. Sabz5150
    Sabz5150 FALCON PUNCH!!!
    How do I pull these friggin things out?! Is there some sort of tool to use? If so, where can I get one?
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    there are a few special tools you need, its a quite involved process.. like heating the head... definately get a helms manual.
  3. Sabz5150
    Fuckit, new head.
  4. CRX-YEM
    Wallingford, CT
    It's not that difficult, I haven't done this to a honda head, but to lotus europa motor,
    the head is aluminum and the guides are usually brass, they have different co-efficients of expansion. you need to hea the head up to some temperature (I think about 100-150deg C) , I can't remember what I set it at before but it needs to be below the value at which heat treating is done our you'll warp and ruin the head. after the head it heated up you can push the brass guiges out, push from the bottom of the head (the bottom is where the combustion chamber meets and you can see the valves) they should slide right out, and you'll need to heat the head again, to push the new guides in.
