valve keepers
Discussion in 'General Tech and Maintenance' started by b16coupe, Jul 5, 2005.
  1. b16coupe
    b16coupe Senior Member
    anderson, S.C.
    will a 91 crx si motor's valve keepers work on a b16a? what are the compatible ones for the b16a?
    Thanks
  2. pissedoffsol
    valve keepers? no such thing.
    if you mean valve springs, or valve spring retainers, the answer is no, they won't fit.
  3. B16CRX
    B16CRX Senior Member
    Greenville, SC
    you need stuff from a 95 del sol vtec.
  4. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Brian, valve keepers are those little things that hold the valve to the retainer. And, no, I don't think they are the same size. The valve stem is a different diameter.
