Vibration in steering wheel- Subaru impreza
Discussion in 'Other Vehicle Discussions' started by Slammed90Lude, Feb 21, 2006.
  1. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    As of late, the car has been transmitting more and more vibration to the steering wheel. THere is also a noise that I believe is coming from the rear tires which I believe to be excess road noise. It gets louder with speed, but nothing else seems to effect it.
    Back to the vibration though, of course there is some vibration all the time, which I assume to be due to slightly unbalanced tires. However, when you hit a bump this is an obscene amount of vibration passed through the steering wheel.
    The tires on the car are crappy, but they still have tread left. However, I noticed that there is some radial dry rot type cracks, which makes me believe these tires are quite old.
    Anyway old tires like that could cause the vibration? Or is it linking to ball joints or something? I don't even know what type of suspension a 99 impreza has?
    Any help
  2. TurboMirage
    i would get the tires replaced, and an alignment at the least.
  3. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    Its your tires.
    Get new ones and get them balanced by someone who knows what they are doing.
  4. ScrapinSi
    ScrapinSi Senior Member
    The bumps causing increased vibration may be due to either a failing wheel bearing, or weak tie rods.
  5. TurboMirage
    i had a good deal of that in the mirage until last weekend. i had a bent motor mount bolt and the rear mount was torn.
    fixed it all for under 5 bucks, and a few hours of my time. :)
    hockey pucks :mrgreen:
  6. ScrapinSi
    And now the car will just rattle itself to death at idle... [​IMG]
    although I doubt that tiny little 80hp weedwacker engine will make enough noise to rattle anything.... :mrgreen:
  7. Celerity
    Celerity Well-Known Member
    My solid motor mount.. just the one, did wonders to the ease of driving and clutching the Civic. At idle, however, it's an ... experience.
  8. TurboMirage
    i know what you mean :)
