VIN id
Discussion in 'General Tech and Maintenance' started by Pep, Dec 8, 2008.
  1. Pep
    Pep New Member
    Inland Empire, CA
    New comer to the forum..... old time racer coming back on the scene.
    I have a 93 Honda Del Sol that's about to get done up. I cannot tell what engine size it is. My engine cover shows V-Tech, but surely does not feel like it. Can I find out my engine size by my VIN?
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    on the block there is a vin tag,its about 1.5 inch by 1.5 inc down on te left side of the header,it will have a letter then 2 numbers then a letter and one more number just read it to us
  3. Pep
    Pep New Member
    Inland Empire, CA
    Cool...will let you know tomorrow.
  4. eg6sir
    my guess is that its a d16z6.. .and the reason you cant feel it is because its single cam...
  5. BrutalB83
    Rochester Hills, MI
    That's the engine ID code, not the VIN. A VIN is something completely different...
    :werd:
    Is it a single-cam engine? Or dual-cam? If it's a single-cam, then it's a D16Z6. If it's a dual-cam, then it's a B16A3...and this is assuming that the engine in question is the stock engine...
  6. 95b16coupe
    95b16coupe New Member
    ct
    re-read your valve cover. i would bet you $100 it doesn't say V-Tech on it.
    anyways, just check the block. it has the engine size on it. what year is it? b16's didnt come out until the later years.
  7. eg6sir
    b16s came in 94-97 Del Sol VTECs
