vitara d16
Discussion in 'Forced Induction' started by BoostedSol, Sep 11, 2006.
  1. BoostedSol
    BoostedSol New Member
    I have heard about putting vitara pistons and stuff into a d16 turbo and it lowers the comp ratio and is alot stronger and can run safely 12-15 pounds, is this true?what other parts do i need for the bottom end rebuild.
    Ben
  2. formby
    formby learning in progress
    its true
    the only reason you can run more boost is because of the low ass CR.
    in HT you can search for panda motor..
    you can use b16 rods or you can buy the cheaper tuner toys rods [they are forged] but youll have to notch the block with the TT rods
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Not 100% correct...
    The pistons that people like to use are aftermarket pistons made FOR the Vitara that are actually stronger than factory. Pair them with B16 rods and you have a cheap combo that can handle a od bit of boost.
  4. BoostedSol
    where would i get these rods and pistons from and roughly price? I live in ontario canada, know any good shops or websites?? also i have a friend offering to sell me his 9lb fidenza flywheel and stage 2 excedy clutch for 550. and hes got a skunk to intake manifold he wants 300 for, is this good? would u recommend this stuff on my turbo d?
  5. formby
    550 is a little steep but okay m2c
    300 for the manifold is not good
    Honda-Tech.com: Main has tons of info just search... i wish i could give you more info but i anly know bseries and ef/ek models
  6. BoostedSol
    the parts are brand new, keep in mind its canadian dollars, still not a good deal?
  7. BoostedSol
    where would i get these rods and pistons from and rough price? I live in ontario canada, know any good shops or websites?? Ive been hearing alot of good things about cheap vitara pistons. anyone done this????
  8. phunky.buddha
    Clutch/flywheel prices are good for brand new parts, especially considering you're talking about CAN dollars.
    The piston/rod combo can be found by searching for "TurboPanda" on Honda-Tech. He sold them.
  9. BoostedSol
    sorry it was actually a 7 lb flywheel not a 9lb, thanks for the turbopanda search hint
  10. phunky.buddha
  11. BoostedSol
    hmmmmm am having a hard time finding vitara pisonts still
  12. jeffsciv23
    jeffsciv23 Senior Member
    Wa
    look up the user FJT on honda-tech he sells them for pretty cheap. i'm actually planning on building another D series to run while my all motor gsr is getting sleved this winter.
    there are a few people runnign nothign more then vitara pistons, eagle rods, with ARP headstuds and running crazy boost. i'll look and see if i can find the post of one that comes to mind and post it up.
  13. jeffsciv23
    Wa
  14. b20b.eg
    b20b.eg New Member
    the vitaras are on ebay all the time for around 130 shipped tuner toys supplies the rods for 225 plus shipping
  15. jeffsciv23
    Wa
    sounds like a pretty cheap build to me
  16. BoostedSol
    what kind of rods would those be?
  17. hybrid_b18
    hybrid_b18 crew chief
    Burnsville, MINNESNOWTA
  18. Baker502
    Baker502 New Member
    I have a couple of ?s.
    What octain fuel are you running for the 400hp,and how well was it tuned?
    At the strip what type of tires did you use?
    Did you have to bore out the block for the vitara pistons?
    And what piston rings did you use?
  19. Baker502
    Baker502 New Member
    also what vitara moter did you pull the pistons out of?
  20. jeffsciv23
    Wa
    you should always run 91 octane when driving a boosted car, and the numbers show it was tuned well, probly runs 24" slicks or slightly smaller, the pistons drop right in a stock d series and come with rings normally if you get them from FJT or ebay.
