vss issues
Discussion in 'ECU's, Electronics, and Tuning' started by Dark91zc, Jun 30, 2005.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    ok everthing is hooked up and electrical is all done but my speedo still wont work. i am running the 99 integra vss electronics and the 97 del sol gearing and everything hooks up fine so now to the wiring i have a yellow with black stripe, yellow with white stripe and a black wire. now black should be ground and the yellow/white should be signal right.on the ecu i used the ecu pin b-4 should i use a25??
    thanks for the help
    lance
  2. 88bluehf
    88bluehf Senior Member
    Denton,TX
  3. Dark91zc
    Corona,CA
    i went by that and used the b4 pinout?? i might change the pinout to the a block and i will see from there
