vss on 88 hf code??
Discussion in 'HYBRID -> ED-EF / DA' started by need2bfast, Mar 13, 2004.
  1. need2bfast
    need2bfast Junior Member
    Hey guys, I am new to this site and have some questions on a swap i just did. I put a b16a w/LSD into my crx hf. The computer is giving a vss code. I understand the computer is looking for this sensor before vtec will work. My speedo is a cable operated unit. How do I make this work like it did from the factory?? I am also getting a collant temp code as well. I swapped it for the other sensor and still the same code. Can you get the two qires backwards?
