alright, here the situation, I running a b20 block with a type R head and PR3 ECU, since i finished the swap, vtec has not been working...and i am out of ideas...the only code that it has been throwing is 22 (VTEC oil pressure sensor) and it has to be mechanical, because it takes a little while for the code to come up (about 3-5 mins drving) whereas when i unplug the senor, it comes up immediatly, and I know the senor is good because we put it on another car and it worked, and i know the wiring is fine (checked multiple times by James Lin=wiring god.) I have tired switching ECU's vtec solinoids, vtec oil pressure sensor, and I have checked that the head has those little pins under the drivers side cam caps, I am preety much out of ideas with excpetion to checking the pins on the lost motion assemblies which i will check soon....but does anyone have any ideas why this would be????????? thanks
