vtec ecu help
Discussion in 'ECU's, Electronics, and Tuning' started by Veetak, Apr 21, 2008.
  1. Veetak
    Veetak New Member
    Oklahoma
    I have a buddy selling a p28 chipped ecu. I have a 1996 hatch, with out vtec.
    Could the p28 ecu work even though its vtec? I know I have to get a obd2 to obd1 convertion harness..only thing that bugs me is if it will work, because its vtec.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    it wont run your car right. why would you even want it if you have a non vtec motor
  3. BrutalB83
    Rochester Hills, MI
    You'd have to get it reprogrammed to run your motor correctly, and that's going to cost you money. I'd recommend just using the stock ECU that goes with the motor for now. If you plan on switching to OBD1 and tuning your car in the future, then maybe buy the P28 from your buddy and just set it aside for now.
  4. Veetak
    Veetak New Member
    Oklahoma
    Thanks Guys.
    I guess I got to find someone to tune/chip my obd2.
  5. AHHVTEC
    Alabama
    why not just use the stock d16y7 ecu
  6. Veetak
    Veetak New Member
    Oklahoma
    yea thats what I am going to do. Just need someone to tune it, or i might run a safc.
  7. t3t4delsol
    t3t4delsol New Member
    York, Pa
    are you going turbo or something that requires another tune then the stock bin? You cant chip a obd2 ecu, and if you are turboing get the 0bd1 p28, and a 0bd2a to obd1 conversion harness. If your tuner knows what hes doing he can turn off vtec in the tune
  8. Veetak
    Veetak New Member
    Oklahoma
    wooohoo finally someone that knows!
    Yea, thats what I need done. You think I can use this p28 vtec obd1 ecu this guy is selling? And yes its going to be boosted.
  9. t3t4delsol
    York, Pa
    yes that not a problem, When I was tuned I had my tuner turn off all cel codes also, just incase for emission purposes. I know vtec can be turned off in Chrome. Good luck with the build if you have any more questions feel free to ask :)
    also, your still going to need the bin retuned, and when your ready to get tuned, either have your tuner install your larger injectors or do it yourself and have it towed to him. once you install your larger injectors your car will not start without being tuned for it
  10. AHHVTEC
    Alabama
    it would have helped if you told us you was turboing from the start
  11. Veetak
    Veetak New Member
    Oklahoma
    My bad man.
    why would i have a stock n/a tuned?
  12. AHHVTEC
    Alabama
    no clue yu would be shocked at some of the da questions we get around here lol
