vtec not engaging
Discussion in 'Engine Building' started by turboef87, Mar 8, 2010.
  1. turboef87
    turboef87 New Member
    i changed my cams today put gsr cams in a b16 vtec is not poping like it uzed 2 wat could be the problem ??? i think itz the vtec solenoid
  2. Briansol
    vtec solenoid, proper oil prssure, and engine temp are required for vtec to engage.
  3. turboef87
    iiight so what should i do thiz iz my first b16a i dnt have 2 much experience with vtec
  4. Briansol
    are you throwing a CEL? if not, it's not the vtec solenoid. if it was bad, it would throw a code.
  5. Magana559
    Magana559 The Warden
    fresno Ca
    all motor or Forced induction?
    Plus Vtec dosent Pop, crack, kick in, or slam you back into your seat. Vtec is suposed to be smooth.
  6. turboef87
    i took the car out today and it waz hittting vtec but not really noticable... soundz more like an ls... could it b the timing is offf the distributor was played with and the kid that put the gsr cams in i dnt think it waz excactly tdc im gonnna re time everything and seee if thats the problem
  7. turboef87
    yeaa check engine light is on i gotta get the codes for it i think its from my throttle body and intake manifold i changed them 2
  8. turboef87
    itz all motor rite now but it will be boosted
  9. Matts96HB
    Matts96HB . Moderator VIP
    pull the codes. then come back with your issues. it'll be easier to help you that way.
  10. turboef87
    im gooood i put the distributor back 2 normal and itzz pulllen nowww
  11. mcmurtry1986
    mcmurtry1986 New Member
    if the MIL is on the vtec will not engage either
  12. mcmurtry1986
    how do i start a new thread man, im new to this forum stuff, please help me
  13. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    go to the honda forum and select the right section for your thread and look on the horizontal selections Forum tools has a 'start a new thread'...pretty easy from there.
  14. mcmurtry1986
    what do you mean "go to the honda forum" i still dont know how to do it
  15. CAFROG
    NOR-CAL
    Honda Swap Forum home page then pick the correct section then click on forum tools and select 'start new thread'
  16. Briansol
