im not sure if my vtec is working properly, i believe i wired everything up correctly but at the same time i cant feel/hear the vtec kick in when accelerating. Is there a way i could test to see if the vtec is indeed engaging?
Someone on here said that the CRX HF has a Shift light on the dash that you could tap into the vtec wire so that it would light up in vtec, so could i just wire in a bulb of some sort to test?
any help would be appreciated.
thanks
thanks
