vtec wiring, yes another one of those thread
hmglauj
i read and re-read the article here and everywhere i can find but still cant figure it out.
i have a 95 gsr in a 92 dx, 95 gsr engine harness and 92 subharness.
i checked the ecu plugs and A4,A20,D6 (vtec solenoid/evap/vtec pressure switch) where already pre-wired. so thet only wires left that i need to wire are...
iab -> A17, evap power -> power, and ks -> D3.
right?? correct me if im wrong.
here's the thing though, when i located the pink/blue (iab) wire, which was on the connector on the driver side, is it suppose to be over there? so when i located the pink/blue (iab) wire on the male connector there's a wire on the female connector that connects to it already. i think it goes to ground :huh: !?
and the yellow/black wire (evap power) has a female end wire yellow/blk also
when it's labled, example.. "org/wht" is it the same as wht/org, does it matter?? is orange with white lines the same as white with orange lines??
help me out guys
