VX-DX head swap?
Discussion in 'HYBRID -> EG-EK / DC' started by OldSchoolSwap, Nov 14, 2003.
  1. OldSchoolSwap
    OldSchoolSwap Senior Member
    I have a VX with bent valves, my friend is giving me his DX head. Can i run the DX head on my D15Z motor? Keep in mind that the D15Z HX civic is a VTEC-E motor and the DX is not.
    Here are the specs on both motors......
    D15B7 92-95 CIVIC DX/LX 1493CC 102HP@5900 95FTLB@5000
    4CYL, 16 VALVE REDLINE:6800
    SOHC
    D15Z1 92-95 CIVIC VX 1493CC 92HP@5500 97FTLB@4500
    4CYL, 16 VALVE REDLINE:7000
    SOHC VTEC-E
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    yea you can do it, I think you'll need a new ecu though, and if the dx head is obd1 you gotta swap the distributor
  3. MaliWho97
    MaliWho97 Senior Member
    Yo man, just try to find a D16Z6 head and Intake manifold right now.... Its a VERY simple mini me swap.
  4. OldSchoolSwap
    I think i'm a give it a shot and keep ya'll updated. The only thing i will use is the DX head and keep everything else as is, i will reuse the VX manifold. This way, all sensors will remain the same, except the "minus" vtec selenoid on the head.
