waste gate help
need2bfaster
this week end i am starting to turbo my car i have no idea how to hook the wastegate up
4 or 5 lb spring, im guessing its a external wastegate, also what are you using for a boost controller because that will be involved in hooking up the wastegate
turboxs sbc and will tial spring fit in a jdmsport wastegate
do i need a dump pipe for my waste gate or is that an option and i am guessing that are different sizes of wastegates cause the one i have seems to be to tall
so the part with the spring faces down toward the manifold the open part gets a dump pipe bolted on to it and welded into the downpipe??
no, you can just run it straight out it doesn't need to be recycled back in to the exhaust
It doesn't have to, but there was a good reason to "recycle" it, I can't remember it though.
I personally just vented it into the atmosphere.
