wastegate spring test
Discussion in 'Forced Induction' started by turboef87, Dec 7, 2009.
  1. turboef87
    turboef87 New Member
    im checking my wastegate spring b 4 i put it in my car.. what do i need??? im just checking when the wastegate actually starts to open.. and i wanna kno were i can buy what i need to test it
  2. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    do you mean check what psi the spring is or what?
  3. turboef87
    yeaa at what psi does the spring open the wastegate... can i hoook it up to a pump with a pressure gauge then just addd presssure tilll the wastegate cracks that should telll me ritee
  4. DESPAIN
    flower mound TX
    put in your car and hit full boost! rep+ me!
  5. Matts96HB
    Matts96HB . Moderator VIP
    :slap:
    Find someone with an air compressor with a regulator. Hook the boost only port on the wastegate to the hose on the air compressor (using a nozzle or whatever). Set the regulator on the compressor to about 50psi and try it. Keep in mind that there will be no pressure on the wastegate from the exhaust so whatever pressure you use on the compressor divide that by two and that will be right about where it'll open. You can do this on or off the car. On the car might give you a more accurate idea.
  6. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    I think that is the worst idea ive ever heard
  7. DESPAIN
    flower mound TX
    wam bam thanks man......lol but honestly i looked all my springs up from color codes and i never get exactly what they say it is. always close but never exact.
  8. DESPAIN
    flower mound TX
    it also will depend on how you have vac. setup and where. also where your waste gate sits on the mani. several variables involved. just because it tests at 89psi doesnt mean thats what you get when you hook it up.
  9. Matts96HB
    Notice how I said its approximate. There's no possible way to manipulate it exactly. But driving the car and figuring out where it opens is not a good idea. Especially because from the sound of it the car isn't tuned. Bad idea.
  10. DESPAIN
    flower mound TX
    well get it tuned ofcourse. my s100 has a cutoff @20psi
  11. Matts96HB
    And my CROME has a cutoff @ 25 PSI. Because they do the exact same things really. :D
  12. DESPAIN
    flower mound TX
    just saying more options with hondata.
  13. Matts96HB
