Water leak on the S14
Discussion in 'Other Vehicle Discussions' started by Capt. Orygun, Oct 26, 2006.
  1. Capt. Orygun
    Capt. Orygun Win the Day
    Oregon
    WTF, will this thing quit breaking?
    I've got a water leak, it's not spilling out but it is a fair dripping leak. Looks like I need to add coolent about once weekly. The water drips from right around the fan area of the front of the motor and seems to me more previlant during idle then operation, but I can't even being to validate that last assumption.
    So I haven't taken a decent look at it yet but I'm guessing the water pump seal? Do I need to replace the pump as well (it's at 160K miles), or is the seal good enough?
  2. Celerity
    Celerity Well-Known Member
    No, it's a fuckin Nissan !
    Better save up for brake calipers, it's been 9 months and it's time for those to break too.
  3. Capt. Orygun
    Oregon
    already have a set of R33 calipers awaiting rotors, pads, lines and a new master cylinder (christmas list much?)
  4. TurboMirage
    nissans are horrible maintenance pits.
    think about it, homie. your water pump is on the front of the motor.
  5. Capt. Orygun
    Oregon
    yeah but the pump seems to still be working, should I replace it at 160K to make sure there isn't a future problem?
  6. TurboMirage
    doesnt matter if its working or not, its a cheap fix. and 160K is alot of mileage on those bearings...
  7. Capt. Orygun
    Oregon
  8. TurboMirage
    good call. usually i will replace the t-belt/water pump/front main seal on a car that i just bought - unless it has paperwork telling me it was done at such and such a mileage. 75K otherwise :)
  9. get_nick
    Washington State
    ka's are a dime a dozen. it would take less time to do a swap and be a hell of a lot easier. timing chains on those suck and are expensive. save yourself the money and get a longblock for $150.
  10. TurboMirage
    expensive? i paid less than $200 and put that shit on myself....
    thats not too bad at all. easy, too. worst part is that freaking fan and shrowd.
    swap in another motor? for a timing chain? fuuuuck that.
  11. get_nick
    Washington State
    well, if you get a longblock for $150, you will have an engine with 50,000 less miles on it and not have to fuck with any of the problems. nissan swaps are easy.
  12. Capt. Orygun
    Oregon
    if it's anything like I changed on the planes it's like six bolts, a seal and a drive spline...
    but the car's water pump is belt driven right? so no drive spline?
  13. TurboMirage
    correct. a belt and a few bolts. some RTV. done.
  14. Capt. Orygun
    Oregon
    what's the RTV for? I hate drive belts :-(
  15. TurboMirage
    seals the pump to the block.
  16. Capt. Orygun
    Oregon
    isn't that what the gasket is for?
  17. TurboMirage
    some water pumps dont have gaskets.
  18. Capt. Orygun
    Oregon
    ?!? who the fuck designed that shit?
    this is something I've had a real hard time with, with airplanes EVERYTHING had a gasket, you reseal it, bolt it down, goodnight.
    do auto manufacturers do this shit on purpose?
  19. TurboMirage
  20. Capt. Orygun
    Oregon
    PHUK UR SMILI NICKA!!!
    (rep point 4 j0)
