Water Temp/ Oil Pressure Guages
MugenCRX89
how do i hook these up? i have a odb0 b18 crx. please let me know
what brand of gauges? is the oil pressure gauge electric? for most aftermarket electric gauges, you need matching sending units on the engine
Get a half inch drill bit tap the line into the back of your block this will give you the most accurate reading id recommend steel braided lines from evco
