Were Can I Buy Preformance Cams That Are Regular?
Discussion in 'Engine Building' started by hondacivicnos, Feb 26, 2003.
  1. hondacivicnos
    hondacivicnos Senior Member
    Were can I buy Preformance Cams that are regular? (I mean this will work as the one that I have in my engine right now)
    And my engine is b18c5
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    This makes little to no sense. :huh:
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Go to an acura dealer and buy OEM ITR cams. IF you just want to keep your stock idle, get a skunk 2 valve train set. They can give up to 12hp vs. ITR cams.
  4. bsi101
    bsi101 Junior Member
    Contact GUDE performance @ gude.com if your on a budget. They can cut your cam cores to any grind you want, stock idle to full race. If cost is'nt a factor, go w/Crane or Crower. New cores, factory base grind, less valve traine weare. OEM ITR is a good choice for close to stock idle, but there not cheep.
  5. B16
    B16 Super Moderator VIP
    yay area, CA
    uhh, guys, he has a b18c5, so he already has ITR cams in there, lol! if you want to swap cams without upgrading your valvetrain get either toda spec a's or skunk2 stage1's... any others you will need upgraded springs/retainers.
    do not get gude, reground cams are crap, dont be mean to your type-r.
  6. xj0hnx
    C.C.TX.
    I still want to know why you'd want to buy performance cams that are same as the ones in your motor?
  7. Darivative
    Darivative Guest
  8. bsi101
    B16'S right! i mixed up C1/C5. I never said GUDE was gold. Read: " On a budget" and " Valve train wear" SKUNK cams are re-grinds too, whats the differance.
  9. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Actually you are incorrect sir
    direct from the skunk2 site.
  10. B16
    yay area, CA
    well, the difference is skunk2 cams are NOT regrinds, like lsvtec said :)
  11. cws13
    cws13 Senior Member
    Athens,GA
    Gude= damaged motor. Stay far away. Trust me, I've seen him return a head so fucking warped that it leaked externally, and replied " I don't know how much we took off. (It turned out to have a static compression ratio of over 16:1 and had to be thrown away!!!)
