werid cel light?
Discussion in 'HYBRID -> ED-EF / DA' started by david_jones001, Mar 8, 2005.
  1. david_jones001
    david_jones001 Senior Member
    Arizona
    I get a check engine light whenever im in a high gear like 5th or 4th and let it come down of the rpms to like 2 thousand, the cel light comes on, then when i start the car after i turn it off, its gone, only does it if i let the rpms drop really low in a high gear, or even like 3rd gear and drop down to 1500, anyone got any idea why its doing this, i dont really care cuase i drive it normal without droping the gears so low in higher gears, but everyone once inahilw ill forget and it will do it
  2. bte15
    bte15 Senior Member
    Bellevue, Washington
    knock sensor problem is what it sounds like
  3. nfn15037
    nfn15037 Senior Member
    Pull the CEL code before you shut it off.
  4. darien234
    darien234 Senior Member
    Or the 02, I had the same problem do you have a cat and motor is it.
  5. david_jones001
    Arizona
    no cat, but i do have a 02 sensor before where there whould usally be a cat, its a ls vtec motor
  6. darien234
    What ecu is it a p28, yeah it might be that cat deficiency code.
  7. david_jones001
    Arizona
