what alternator do i need for a b18b1 swap?
Discussion in 'Civic and del Sol - EG and EK' started by fishbowl, Jul 15, 2015.
  1. fishbowl
    fishbowl New Member
    i have a b18 b1 swap and my altnator isnt charging the battery what alternaton do i need and if i need to what sive battery should i get i have the whole car shipped and it has launch contol i just want to make sure im getting enough power to every thing
  2. Briansol
    What car is it in?
    What ecu are you using?
  3. fishbowl
    fishbowl New Member
    its in a 93 honda civic hatch
  4. fishbowl
    fishbowl New Member
    i dont know the ecu on the top of my head
    but ill get back to you on that
  5. Briansol
  6. Secret Place
    Secret Place Member
    queens ny
    Have you checked the wireing on your alternator? My alternator was fine but the wires on the green plug were cut and had contact with the wire next to it, therefore causing the alternator to not hold a charge.
  7. Secret Place
    Secret Place Member
    queens ny
    I have a P75 ECU in mine and it runs fine. Besides it having one code. the Crank sensor code
